At this moment we are still busy creating an import function for MyRoute-app Navigation.
As long as this is not ready, importing a GPX needs be done with a workaround.
You can log in with the same account credentials on MyRoute-app Web (www.myrouteapp.com) as you use for the navigation app. Once logged in on www.myrouteapp.com, you will find the button "import" In "Routelab".
A GPX file can contain routes and/or tracks. Depending on what your file contains and what wish to import, you can follow the steps below:
Route:
- Import the GPX as route.
- Check the route for errors.
- Reload MyRoute-app Navigation.
- The route will appear in your route list.
Track:
- Import the GPX as route-track.
- Select "use as route" to convert the route-track to an editable route.
